Another Toilet-Related Hazard
A Delta Airlines flight from Minneapolis to Las Vegas made an emergency landing in Vegas Thursday, when the pilot was locked out of the cockpit after taking a bathroom break.
The pilot addressed the passengers, saying, “I have some bad news,” passenger Jonathan Thalacker told ABC News. “I had to go to the bathroom, and when I came back out, I got locked out of the cockpit, the door is jammed.”
The first officer took over the controls and landed the plane. The MD-90 aircraft [Note, apparently not Dummy Pilot] was not damaged, and none of the 168 passengers onboard were injured. The plane landed at 12:23 p.m., just 13 minutes after the emergency was declared, reports the Associated Press.
The plane had to be towed from the runway to the gate, because the co-pilot did not have access to the taxiing controls from his seat, passenger Jesse Dougherty told ABC News. But the plane still pulled into its regular gate at McCarran International Airport on time, at about 12:30 p.m.
Once on the ground, everyone on the aircraft started applauding, hollering, and calling out, “Thank God,” said Thalacker.
Airport spokeswoman Christine Crews told ABC that a door malfunctioned, it was an “unusual landing,” and the whole incident was taken very seriously.
Delta spokeswoman Lindsay McDuff said Delta crews are trained for these situations, and a commercial aircraft can be landed safefly with just one pilot. She said the doors are being studied by maintenance technicians.
A passenger told ABC that the maintenance crew found a piece of string that kept the door from opening, but that information has not been confirmed by officials.
http://www.boston.com/travel/2015/01/30 ... story.html
Re: Another Toilet-Related Hazard
Good Lord, the danger here is that the poor FO may still be trapped in the cockpit?!?!?!?
I think it's time to ban bathroom breaks for the pilots and force them to wear diapers.
I'm sure Dummy will agree .
I've actually had a few troubles with the -90 doors (no problems with the -88s). This includes one where after arriving at the gate we spent a good 5 minutes trying to get ourselves out.....thank god it wasn't on the last leg of a 4 day or I would have evacuated out the window.
They have very quickly sent out a bulletin saying that they have identified the issue and there will be an update on the VOL 1 preflight procedure and VOL 2 systems description.
Potty training?Delta spokeswoman Lindsay McDuff said Delta crews are trained for these situations
I've been trying to think of bad jokes regarding FCOM and QRH and procedures and fundamental basics and the specific procedural differences between an MD-88 and and MD-90, and what to check for before you pull up relentlessly on your zipper, or with regard to the operation of the TP roller, and modern facilities with auto-flush, vs. less fancy manual flush, and specifics regarding round vs. flat interfaces and whether it should be left up or down...
...I would have to say that my limited experience with the C-172M and on-board restrooms limits my ability to comment, and also say that MSFS does not really simulate things well enough for me to operate Dummy's equipment in case of emergency.
3WE:
I bet that makes DP happy.well enough for me to operate Dummy's equipment
- Robert Hilton
There are so many jokes in that alone!3WE:I bet that makes DP happy.well enough for me to operate Dummy's equipment
