Full article, video and pictures HERE.A Daallo Airlines Airbus A321-100, registration SX-BHS performing flight D3-159 from Mogadishu (Somalia) to Djibouti (Djibouti) with 74 passengers and 7 crew, was climbing out of Mogadishu about 5 minutes into the flight when an explosion was heard. The crew stopped the climb and returned the aircraft to Mogadishu for a safe landing about 20 minutes after departure. A large hole was seen at the right hand side of the fuselage above the wing. Three occupants were taken to hospitals with injuries.
Daallo A321, explosion in flight makes hole in fuselage
Re: Daallo A321, explosion in flight makes hole in fuselage
Additional information here
http://www.theguardian.com/world/2016/f ... -explosion
Hole seems to be about a metre high by about 50cm wide. Respectable size.
Patch it up and away we go. Bit of gaffa tape will fix that.
I am becoming more impressed with the cheap composite crackerbox. It seems to be surviving a lot of things largely in-tact in contrast with "other incidents".
Keep layering your fiberglass and your dent-repair bondo and you get a light weight material stronger than steel, right? (Just lay off the rudder)
Hopefully the "passenger sucked out" was a bad guy.
Fixed.Keep layering your fiberglass and your dent-repair bondo and you get a light weight material stronger than steel, right? (Just lay off the rudder and try to maintain fat, dumb and happy speeds and attitudes).
