Turbulent Landing
Turbulent Landing
Postby monchavo » Fri Jan 19, 2018 10:26 am
https://www.youtube.com/watch?v=GKBI_bV ... e=youtu.be
This is jolly fierce. Probably the worst I have ever seen.
Comments?
Re: Turbulent Landing
Postby 3WE » Fri Jan 19, 2018 10:42 am
1. "Yes" and "Like"
2. General rule: Winds become less turbulent closer to the ground.
3. Among the worst in terms of approach, but a perfectly acceptable, nice touchdown and roll out.
Postby Rabbi O'Genius » Fri Jan 19, 2018 12:13 pm
Absolute rule: At ground level the vertical component of the air movement = 0
Rabbi o'Smartass
Postby Not_Karl » Fri Jan 19, 2018 12:41 pm
I hope that no drinks were spilled.
Postby 3WE » Fri Jan 19, 2018 2:14 pm
Rabbi o'Smartass
1. However the lateral component does not = zero.
2. and 10 feet above the ground, where the wings work,, the wind CAN have a vertical component
3BSmartass ;)
Postby Rabbi O'Genius » Fri Jan 19, 2018 2:24 pm
Rabbi o'Smartass
3BSmartass ;)
One cannot disagree with any of the foregoing statements.
Postby 3WE » Fri Jan 19, 2018 2:30 pm
Rabbi o'Smartass
3BSmartass ;)
Especially, but not limited to, the smartassery :mrgreen:
Postby flyboy2548m » Fri Jan 19, 2018 2:43 pm
Absolutely tremendous job by the crew, all kidding aside.
Postby 3WE » Fri Jan 19, 2018 4:54 pm
I am torn by:
The Evan thought: "Isn't there a point when you should just stay on the ground or go someplace else where the winds are better...geemanitly that looks extreme and you'd think there is an elevated risk of some bent metal or tracked up grass/busted runway light..."
VS
My inaccurate view of reality: "We are professional, highly- skilled pilots and can fly down close to the ground and see if the winds become manageable with an excellent safety buffer and competently do one of those go-around things if not...."
Postby elaw » Fri Jan 19, 2018 8:58 pm
Agreed! There's a lot of discussion of pilots screwing up on this and other fora, much less frequently do we see credit given when it's due.
I think credit should also be given to any of the pax who were able to retain the contents of their stomachs. :lol:
Edit: and those who had to clean up after those who didn't.
Cowboy Improvisational Airmanship
Postby 3WE » Fri Jan 19, 2018 9:03 pm
https://www.youtube.com/watch?v=AuXH1htEhyc
Was this approach stabilized??? I do not think we were on the centerline EVER...still turning at what? 100 feet?
Ok, trying to be a little bit serious- I am a little surprised he didn't do a little better at having a something of a "final approach leg", nor landing dead-on the centerline...just because isn't that what cool people do? Disclaimer: I would confess, it appears to be perfectly acceptable, competent airmanship- he even dutifully consulted the landing checklist- definite atta-boy in the procedure department!
Back to asshattery- should I post this, there with something about Cowboy unstabilized Approaches to see if the trolling gets any bites?
Re: Cowboy Improvisational Airmanship
Postby Not_Karl » Sat Jan 20, 2018 1:40 am
Do you expect any other answer than "of course!"?
Postby elaw » Sat Jan 20, 2018 2:08 am
We call that the "simulated Kai Tak arrival", where you fly a beautiful approach to a runway then at the last minute change your mind and land on a completely different one. 8-)
Fun fact that I'm sure nobody cares about: a Cape Air flight from HYA to ACK in a plane just like that one is what spurred my interest in light planes and led me to take flying lessons.
Postby Gabriel » Sat Jan 20, 2018 11:12 am
Superior pilots use superior judgement to avoid using superior skills.
Postby monchavo » Sat Jan 20, 2018 11:25 am
I think it's likely that many lunches were spilled, that was a rollercoaster. Nasty.
Postby monchavo » Sat Jan 20, 2018 11:26 am
Yes, very impressive. But it does beg the question - why - surely that amount of movement and buffeting calls for another go once it has died down a bit.
Postby elaw » Sat Jan 20, 2018 2:54 pm
We recently had several bouts of weather that brought winds similar to those shown in the video. In at least one case they lasted for a day and a half... that seems like kind of a long time to hold. :mrgreen:
Postby flyboy2548m » Sat Jan 20, 2018 4:14 pm
No.
Postby 3WE » Sat Jan 20, 2018 4:42 pm
No.
Upon further thought, there tend to be scientifically inspired operational limits that were probably followed here if I were to guess.
Postby Gabriel » Sat Jan 20, 2018 5:07 pm
Then don't take-off. Take-off is optional. Landing is mandatory.
Unless it was a totally unexpected and unforecasted situation that the pilot and dispatched could not have been aware of. Which I doubt.
I wonder if procedures were violated there (stabilized approach, max crosswind allowed by the operator, etc...)
Don't get me wrong, that looks like a beautiful display of stick-and-rudder skills (although at the same time I wonder if a good part of the motion is not the pilot overreacting, as it is sometimes the case). But if it was avoidable at all, it should have been avoided. Not only it is dangerous, but it must have been a terrible torture for the passengers.
Postby Gabriel » Sat Jan 20, 2018 5:08 pm
I wonder if the opposite is true.. Stabilized approach? Max crosswind (including gusts)?
Postby 3WE » Sat Jan 20, 2018 7:59 pm
***Stabilized approach***
What is a stabilized approach?
That you were not grossly high and fast and behind on duties and checklists but instead are within a good range of height and speed for most of the approach (or at a declared ‘safety point’)?
OR
Rock solid, minimally deviating airspeed, attitude, heading and ‘glideslope’ with minimal control input effort?
Evan mentality of a written rule or the fundamental of are you fat, dumb and comfortably in control?
Postby Not_Karl » Sat Jan 20, 2018 8:40 pm
Plot twist: There was no wind, the movements of the aeroplanie are the result of rudder reversals and other monkeying by stupid pilots.
Postby Gabriel » Sat Jan 20, 2018 10:56 pm
https://flightsafety.org/files/alar_bn7 ... edappr.pdf
Postby 3WE » Sun Jan 21, 2018 8:33 am
So, the Evanie, Regulatory, Written, meet A, B, C, D, at altitude X...
Not so much 'comfortably in-control' with fat, dumb and happy margins...
Users browsing this forum: Baidu [Spider] and 1 guest
