A-10 and Su-25
A-10 and Su-25
From the Warthog Blog http://warthognews.blogspot.com/2009/04 ... ezmer.html
Nice pic (that I do not recall have seen before in this combination): A Su 25 Frogfoot and and A-10 Warthog in one photo:
Pix were taken at the "Reunion Aprill 2009" meeting of Bulgarian and US fighter pilots.
Re: A-10 and Su-25
Tacically speaking has the Su-25 seen & delivered any real results in the "real world"? I saw a stat provided (do not remember the source) that stated that the warthog has destroyed more tanks in combat than all other aircraft combined...
proudly serving WTF comments since 2003
Re: A-10 and Su-25
More than Il-2?I saw a stat provided (do not remember the source) that stated that the warthog has destroyed more tanks in combat than all other aircraft combined...
Re: A-10 and Su-25
He probably means all "modern" a/c.More than Il-2?I saw a stat provided (do not remember the source) that stated that the warthog has destroyed more tanks in combat than all other aircraft combined...
Il-s, with 36k pieces (plus/minus) produced surely has a lot of tanks on its kill list, also the FW-190F-2 and the Stuka Ju-87G-1 (and the -3, with two 37mm AT cannons mounted underwing and the dive breaks removed) came up to many more tanks that the Warthog ever could have killed (9.000+ T34 IIRC, Battle of Kursk just one example, but also did much harm in Africa). Just Col. Hans UlrichRudel killed 450+ alone on the Stuka, and many more with the AT equipped FW 190... (http://www.youtube.com/watch?v=sZ8EqJlOsUk)
http://www.youtube.com/watch?v=uEovxiP2Rxg
http://www.youtube.com/watch?v=kLDhZH0-aDU
http://www.youtube.com/watch?v=WRUj6RiCj4w
http://www.youtube.com/watch?v=dYijHuyQW9A
Re: A-10 and Su-25
Well... I meant of all time... this is what I get for reference some stat that I did not really remember. In terms of modern attack aircraft is there anything comparable in terms of combat experience?He probably means all "modern" a/c.More than Il-2?I saw a stat provided (do not remember the source) that stated that the warthog has destroyed more tanks in combat than all other aircraft combined...
Re: A-10 and Su-25
Havent seen any realativating stats about sorties/hrs etc., but at least in absolute numbers there were (so far) less Warthogs than Su 25 downed in Afghanistan IIRC.
- Princess Leia
Re: A-10 and Su-25
Correct. There haven't been any A-10s lost in A-stan. Surprisingly very few lost in both Iraq incursions, and though some took very heavy damage in Kosovo (including having an engine blown completely off by a MANPAD), none lost there either.Havent seen any realativating stats about sorties/hrs etc., but at least in absolute numbers there were (so far) less Warthogs than Su 25 downed in Afghanistan IIRC.
May a plethora of uncultivated palaeontologists raise the dead in a way that makes your blood boil
Re: A-10 and Su-25
I don't think the comparison is fair to either aircraft. They were built for different purposes.
Re: A-10 and Su-25
Are you fuckin shitting me flyturd... both are close air support for ground troops and heavy anti tank focused weaponry and avionics/guidance/sensor packages. Sheesh man.. get you ass out of your head.I don't think the comparison is fair to either aircraft. They were built for different purposes.
Re: A-10 and Su-25
Go f*** yourself, sean. The Su-25 wasn't designed with as an "anti-tank focused weapon" (unlike the A-10), it was designed as basically a heavy COIN bird with other capabilities (such as anti-tank). It was also designed for a very different theater and operating environment. You may recall the Soviets were mired in a certain country back then.Are you fuckin shitting me flyturd... both are close air support for ground troops and heavy anti tank focused weaponry and avionics/guidance/sensor packages. Sheesh man.. get you ass out of your head.I don't think the comparison is fair to either aircraft. They were built for different purposes.
Get back to your busboys, dipshit.
Re: A-10 and Su-25
OK.. so maybe I went a tad bit overboard in my reaction to your ridiculous post but design purpose and utilization purpose are two different things. The 747 was not designed as a freighter but miraculously... it is now. The c-130 was never designed as a gunship however through engineering ingenuity it is now.. the current utilized purpose of both the a-10 and the su-25 are quite similar close air support for ground troops and heavy anti tank focused weaponry.Go f*** yourself, sean. The Su-25 wasn't designed with as an "anti-tank focused weapon" (unlike the A-10), it was designed as basically a heavy COIN bird with other capabilities (such as anti-tank). It was also designed for a very different theater and operating environment. You may recall the Soviets were mired in a certain country back then.
Care to comment on the effectiveness of one over another in this role?
- Robert Hilton
Re: A-10 and Su-25
If you would be kind enough to leave the handbag fighting to OTF and just put your arguments without the insults.
You both have valid points might I add.
Re: A-10 and Su-25
concur... I stated the same in my last post.If you would be kind enough to leave the handbag fighting to OTF and just put your arguments without the insults.
Re: A-10 and Su-25
Horseshit. The freight mission was very much a part of the 747 design. Hence the high-mounted flight deck to accomodate a hinged nose.The 747 was not designed as a freighter but miraculously... it is now.
Not really, sean, I can't think of a single conflict in which the Frogfoot was used as an heavy anti-tank platform to any large extent. Most recently during the Georgian conflict they were used to low-level bomb Georgian positions, like a COIN bird would. Pesky things, facts.the current utilized purpose of both the a-10 and the su-25 are quite similar close air support for ground troops and heavy anti tank focused weaponry.
As to which is more effective, perhaps you might ask MikeD, he has hours in one of them.
Re: A-10 and Su-25
Replace 747 with 757 or 767 and my argument remains valid.
Well.. facts are facts and most late revs of the FROGFOOT were specifically designed for the anti-tank role being outfitted with sensors & target designators specifically to support the AT-9 anti tank missile.
Love to chat with MikeD in more detail on which is a more effective A to G platform.. too bad he is not around.
Re: A-10 and Su-25
Well, then why didn't you mention the 757/76 rather than the 74? BTW, it wouldn't have helped your cause one bit, there is still a difference between a purpose-built aircraft and an adapted one. IOW, you would have proven my point.Replace 747 with 757 or 767 and my argument remains valid.
Well, which is it, sean? Was the Frogfoot originally designed for "heavy anti-tank work" as you claimed earlier or is it now being adapted for that role, as you claim now? Can't have it both ways.Well.. facts are facts and most late revs of the FROGFOOT were specifically designed for the anti-tank role being outfitted with sensors & target designators specifically to support the AT-9 anti tank missile.
Yes, he is.Love to chat with MikeD in more detail on which is a more effective A to G platform.. too bad he is not around.
