Oil
Have a question regarding aviation maintenance procedures? Get an answer here!
Moderator: Robert Hilton
Robert Hilton
Re: Oil
Postby Robert Hilton » Mon Aug 18, 2008 10:01 am
Valuable info on VAG lubrication, chaps, but is this really the place?
Seeing as the title is a little vague I think the subject deserves a little leeway.
However should you feel that it needs a seperate thread then by all means.
rattler
Re: Oil
Postby rattler » Wed Mar 25, 2009 4:20 pm
WD40
That is it if you need penetration and have no brass or bronce fittings (I tried it once on my trusty Seagull and got the appropriate punishment for not reading the do.nots...!)
On the other stuff I can hardly comment, as I dont know whether I tried them, in the end it was always the above mentioned WD40...
rattler
Re: Oil
Postby rattler » Wed Mar 25, 2009 4:26 pm
Ouch, I really *love quoting myself*...
Sorry, had not seen this one had already been answered. I guess I will never learn to read through the full thread before hitting "Reply" or "Quote"... happens to me once every week...
WD40
That is it if you need penetration and have no brass or bronce fittings (I tried it once on my trusty Seagull and got the appropriate punishment for not reading the do-nots...!)
IVY MIKE
Re: Oil
Postby IVY MIKE » Fri Jun 19, 2009 8:02 am
the best penetrating oil is mouse milk.i have seen it release 727 bottle bolts that were the worst.
I got a hammer, we can fix that.
Re: Oil
Postby flyboy2548m » Fri Jun 19, 2009 5:06 pm
Allrighty then.
AndyToop
Re: Oil
Postby AndyToop » Fri Jun 19, 2009 11:09 pm
Allrighty then.
GlennAB1
Re: Oil
Postby GlennAB1 » Fri Aug 03, 2012 6:07 am
PB Blaster update: For many years now, every summer when I've turned on the house air conditioner the first time, it hasn't cooled properly. The problem has always been the fan motor seized up. Ever since the first time, I noticed a little rust on the fan shaft right at the housing, a shot of WD-40 has freed it right up. Kind of a pain though, because I have to partially remove the fan to access the area. Well, three seasons ago I sprayed it with PB Blaster and it has fired right up without maintenance ever since.
LOL
Robert Hilton
Re: Oil
Postby Robert Hilton » Tue Aug 21, 2012 8:18 pm
Make sure you clean the condensor and evaporater not forgetting any filters as well.
Good airflow is also paramount for an a/c unit.
GlennAB1
Re: Oil
Postby GlennAB1 » Fri Aug 31, 2012 9:12 pm
Hey! Good to see you're still alive!!!
LOL
Robert Hilton
Re: Oil
Postby Robert Hilton » Sat Sep 01, 2012 7:40 pm
Alive and kicking, just very busy at the moment
GlennAB1
Re: Oil
Postby GlennAB1 » Sat Sep 01, 2012 9:43 pm
Busy is good!
LOL
Return to “Aviation Maintenance Q&A”
