A security announcement
I know I said I was mothballing it ... but seeing as I could, I upgraded the site's security to use https:// this brings it into line with most of the good quality websites on the web- we're up to date with a quality SSL certificate, and your data is transmitted securely.
Please change your bookmark for airdisaster.info to https://airdisaster.info
Thanks
Thanks
Re: A security announcement
Thank you!
AgreeConcurThank you!
Indeed.ConcurThank you!
AD.I stopped remembering me and now I need to log in every time (yes, I do check the remember me box).
May that have anything to do with the improvement?
Are you sure you updated your bookmark to be https and not http?
I had the same problem until I did that.
This problem can also be described as "failure to complete the post-upgrade checklist".
Yup. That was it. My bad, sorry and thanks,Are you sure you updated your bookmark to be https and not http?
Cowboy improvisation.Yup. That was it. My bad, sorry and thanks,Are you sure you updated your bookmark to be https and not http?
Had he followed the correct procedure highlighted by Monchie in his post's ForumCOM instead of relying in universal basic internetmanship skills, this total-login-disaster would not have happened.Cowboy improvisation.
Indeed.Had he followed the correct procedure highlighted by Monchie in his post's ForumCOM instead of relying in universal basic internetmanship skills, this total-login-disaster would not have happened.Cowboy improvisation.
Can Monchie change your userid to Not_Evan, to signify that you Are_Evan? (at least sort of with respect to this post).
I'm Not_Karl_nor_Evan.Can Monchie change your userid to Not_Evan, to signify that you Are_Evan? (at least sort of with respect to this post).
I never understood if with Not_Karl you meant that you aren't Karl (which will give us a bit of information about one thing you are not but not much about what you are) if you are not-Karl (which would mean that you are everything but Karl)
I am not Karl.I never understood if with Not_Karl you meant that you aren't Karl (which will give us a bit of information about one thing you are not but not much about what you are) if you are not-Karl (which would mean that you are everything but Karl)
I am a lot of things -but not everything-, none of which is Karl.
I am not_a lot of people (the voices in my head say we're only 5 at the moment), and none of we is the aforementioned Karl.
Sorry for the confusion, hope this clarifies my identity.
A bit of history:I never understood if with Not_Karl you meant that you aren't Karl (which will give us a bit of information about one thing you are not but not much about what you are) if you are not-Karl (which would mean that you are everything but Karl)
(quote = "A number of AD.com forumites in joking response to certain posts")
Someone was making a preemptive move when they chose their userid.Are you Karl?
PS: How do we work/trick the new quote functionality to manually enter the citationee?
