Boeing Deception: 777X Wing Actually Elongated 787 Wing
Re: Boeing Deception: 777X Wing Actually Elongated 787 Wing
OK, I buy the argument that increasing the aspect ratio can decrease the induced drag.
But what about the tip vortices? If a wing is simply stretched but has the same form and lifting profile at the tip, it’s going to generate much the same vortices at the tip
The claim that winglet orientation is immaterial and that a horizontal winglet prevents air bleeding from bottom to top as effectively as a vertical one needs a bit of justification. From the (admittedly simplistic) “damming air from getting round the corner” point of view, it would seem so much easier for the flow to make the single +180 deg rotation from bottom to top around the tip (and initiate a vortex) instead of the +90, +180, -90 path needed to get round a vertical winglet (or the -90, +180, +180, -90 for a wingtip fence).
Furthermore, if you do have a vertical winglet, why would you give it a “lifting” profile?
If you do, the winglet itself will generate its own tip vortices, and the pressure differential created would assist the main vortex generation by helping move the air round the wingtip from bottom to top. Surely a winglet ought to have a neutral profile and AOA, so that it would generate no pressure differential, less drag, and no tip vortices of its own, and would constitute a buffer zone of “dead air” hindering the flow of air from bottom to top of the main wing.
I think I am beginning to understand some stuff- it's all about trade offs.OK, I buy the argument that increasing the aspect ratio can decrease the induced drag.
But what about the tip vortices? If a wing is simply stretched but has the same form and lifting profile at the tip, it’s going to generate much the same vortices at the tip.
Let's pretend our new tall 737 winglets are very malleable.
If we bend them down, maybe we do lose the vortex killing...but we get MORE lift...a deal that if you are going to put the metal and weight and drag out there, you get a BETTER deal making more lift than you do killing vortexes.
To the snip of your comment- maybe the vortex is the same as it was before...but RELATIVELY it's more wing VERSUS the vortex- thus a net gain (even though you still have the same vortex).
Or this restatement...you have a 90-degree vortex killer, but there's still a big vortex that works around it....so bend it flat and you are still sort of killing the same vortex, but getting some lift while you are at it???
Is that the whole deal with gliders?....really really really long wing with a vortex on the end- which only 'wastes' the outer 3 feet of the wing...vs. a short stubby wing where when you 'waste' the outer 3 feet in a vortex, it's more of the wing being wasted on a percentage basis???
...and you have to beware ammonia volatilization, or you can lose a lot of the N-value of manure.
I will explain more later, but winglets need to generate lift to work. By now suffice to say that another proposed name for this device was "wingtip sail".OK, I buy the argument that increasing the aspect ratio can decrease the induced drag.
Why not right-angle-spill-over-blocking-dam-device or RASOBDD?By now suffice to say that another proposed name for this device was "wingtip sail".
Oh crap...I will explain more later...
The biggest jet engines ever seen are set to roar on Boeing’s 777X
Article with photos including many of Boeing personnel.
The biggest jet engines ever seen are now hanging from the longest wings on any Boeing plane.
Ahead of the new 777X jet’s rollout next month, Boeing offered a first look at these jaw-dropping GE-9X engines inside its Everett assembly plant.
The engine, featuring a huge front fan with 16 carbon composite blades, each twisted into a thin, aerodynamically curved shape, is encased in a carbon composite pod, or nacelle, that gives it a diameter of 184 inches at the widest point.
The engine is the product of an investment of more than $2 billion by General Electric. It was assembled in Durham, N.C., and Peebles, Ohio, from parts built all over the U.S., Europe and Japan. The GE-9X is an evolution of the GE-90 engine, of which more than 2,600 have been delivered. That engine has exclusively powered Boeing’s 777-300ER since it entered service with British Airways in November 1995.
With a maximum engine pod diameter of 166 inches, the GE-90 was previously the world’s biggest jet engine but is now overshadowed by this gigantic GE-9X variant.
The fuselage of a single-aisle Boeing 737 that you might fly on a typical domestic flight would fit comfortably within those outer nacelle dimensions.
Because of the extra aerodynamic efficiency of Boeing’s immense 777X wing, the new engine doesn’t have to be quite as powerful as the current one, delivering 105,000 pounds of thrust compared to the 115,000 pounds from the GE-90. So the GE-9X is projected to burn 10 percent less jet fuel than the current engine.
GE tested the -9X engine in flight for the first time in March 2018, when a test model was mounted to a specially designed pylon on a 747 jumbo jet, replacing one of that test plane’s four much-smaller engines. This spring, the engines will boost the 777X into the sky on its maiden flight, commencing about a year of extensive flight tests.
https://www.seattletimes.com/business/b ... ings-777x/
Here is a short video of a ground test of the GE9X engine on the 747 test aircraft. A new sound is coming.
https://www.youtube.com/watch?v=akdv87P ... e=youtu.be
Initial Test Flight Scheduled for Wednesday March 13.
https://simpleflying.com/boeing-777x-test-flight/
Wing-originated In-flight structural break-up within 7 days.Initial Test Flight Scheduled for Wednesday March 13.
No break-up, it just won't fly. Because we're not 100.0000% sure why it can fly.
Triple post:No break-up, it just won't fly. Because we're not 100.0000% sure why it can fly.
https://www.youtube.com/watch?v=Ld6fAO4idaI
May I direct your attention to the first post on this thread? To wit:No break-up, it just won't fly. Because we're not 100.0000% sure why it can fly.
Bob Feldmann, general manager of the 777X program, in a meeting with journalists .....
“What we learned is this wing loves to fly..."
Right, it is not that it was designed to fly well or anything. Love's ways are mysterious.May I direct your attention to the first post on this thread? To wit:
Do you know the approximate date or year of that performance?
I don't but if you look carefully I think you can see a stegosaurus walking past in the background.
For what it's worth, according to the intarwebs the BBC's first color (oops, colour) broadcast was in 1967 and their programming was pretty much all in color by 1969. And a Wikipedia article implies they first performed that song publicly in 1963. So my best guess is it was sometime between 1963 and 1968.
Also this looks like it may have been the same show: https://www.youtube.com/watch?v=XGCkiwAKl6s So my vote is 1965.
That is almost creepy...(or at least the ironing is very thick!)Gabieee: ***Love's ways are mysterious.***
I agree, but the thought of Gabieee trying to explain love to Evanie….I think the Internet would explode, Gabe's fingers would be totally worn away, and I can't imagine the equations and vortexes that come into play.
Can we isolate it into individual processes or is it a massive, intertwined web of complexity?
Is Evanie even capable of love?
Do any of us truly understand it?
Low Key Rollout for Boeing Employees with various photos and videos.
https://www.dailymail.co.uk/travel/trav ... emony.html
GE 9X Engines Complete Testing
Article includes an image of the GE 9X nacelle which is larger than that of the GE 90, which is larger than the fuselage 737Max, which is...…......
https://simpleflying.com/boeing-777x-en ... -complete/
Initial Test Flight Planned for Late June
Excerpt:
The test flight will likely be too late for Boeing to hit its previous target o flying the 777X to the Paris Air Show, which takes place June 17-23, where it had hoped to make a marketing splash in Airbus’ backyard.
Development of the plane has been slowed by the partial U.S. government shutdown earlier this year and assembly delays on its carbon-composite wings and General Electric Co’s new BE9X engines.
The first two 777X flight test aircraft have left Boeing’s Seattle-area factory and are in integrated system testing on the ground, while the next two flight test airplanes are in final assembly….
https://www.reuters.com/article/us-boe ... SKCN1SZ2SU
Excerpt:
Boeing releases first video of 777X folding wingtip during Paris Air Show
Also some photos of GE9X Engine
https://www.bizjournals.com/seattle/new ... lding.html
it needs to flap faster, it'll never get into the air at that speed.Boeing releases first video of 777X folding wingtip during Paris Air Show
That's good, less chances of total air disasters.it needs to flap faster, it'll never get into the air at that speed.
(total rail disasters still possible)
Boeing 777X will take to the skies Thursday (January 23)
Boeing’s updated 777 wide-body is set to fly for the first time Thursday, beginning a series of test flights needed before the aircraft can be certified for commercial service.
The flight is to take off around 10 a.m. local time (1 p.m. ET) at Boeing’s assembly line facility near Everett, Washington.
The 777X is the latest update to the wide-body airframe that took its maiden flight in 1994 and first came into service about a year later with United Airlines.
Thursday’s flight signals the start of “the next phase of its rigorous test program,” according to Boeing spokesman Paul Bergman. But, he added, the flight could still get pushed to another day.
“Flight testing is dynamic,” Bergman wrote in a statement. “The date could change due to weather and other factors.”
The test flight has already been delayed due to issues with General Electric’s GE9X engines, which have had to undergo a redesign.
This newest version of of the 777 will be the biggest twin-engine passenger jet ever built, capable of seating well over 400 passengers for the larger variant, known as 777-9. The smaller 777-8 will be able to fly farther. Collectively, the two are referred to as 777X. Only the 777-9 has been built so far.
Overall – at 251 feet, 9 inches for the bigger “dash-9 variant” – the 777X will be longer than Boeing’s current-generation 777 models.
https://thepointsguy.com/news/boeing-77 ... -thursday/
2:45 PM ET.The flight is to take off around 10 a.m. local time (1 p.m. ET)
Did they died?
A quick search of the intertubes indicates the first flight is supposed to happen Thursday January 23, which may be "today" for some people but for me it's tomorrow.. today.
POSTPONED
From Boeing:
We are postponing the #777X first flight that was scheduled to take place tomorrow, Jan. 23, due to weather. The team is currently assessing the possibility of flying on January 24. Stay tuned for updates.
7:01 PM - 22 Jan 2020
https://twitter.com/BoeingAirplanes/sta ... 3250310145
From Boeing:
Users browsing this forum: Bing [Bot] and 15 guests
