OMG are they finally going to do it? (B-52 re-engine)
Re: OMG are they finally going to do it? (B-52 re-engine)
I'd like Evanie's opinion on the re-engining of a relic that should have been retired long ago. Hope they don't MCAS them...
Boeing had 2 competing projects.
One project was to replace the 8 engines in 4 pods with 4 modern bigger (+/- 737-like) engines in the 4 pods. That was Boeing's recommended path.
The alternate was to replace the 8 engines with 8 business-jet-like modern engines.
In both cases the engine would be off the shelf, or an adaptation of an off-the shelf engine (not a new development).
The first idea (4 737-size engines) was the most efficient in terms of fuel consumption and time and money needed for maintenance. It had the little problem, however, that a lot of the architecture of the airplane's systems is based on 8 engines, so it was a huge, time-consuming and expensive modification. That was Boing's preferred solution, I assume, because it would mean more money for Boeing.
The second idea (8 business jet sized engines), the one that eventually was selected by the DOD, was easier, faster and less expensive to implement, but would have less fuel efficiency and more maintenance time and cost.
Fuel efficiency is very important because having a lower fuel consumption not only reduces operational cost but, more importantly, allows the plane to reach further on the same fuel, or carry more payload (more "boom") for the same range. While the first plan was better at this, both plans represent a huge improvement from the current planes.
Fixed.The second idea (8 business jet sized engines), the one that eventually was selected by the DOD, was easier, faster and less expensive to implement, but would have less fuel efficiency, more maintenance time and cost and twice the chances of engine failure.
Oh yes, the dreaded 7-engine climb out!Fixed.The second idea (8 business jet sized engines), the one that eventually was selected by the DOD, was easier, faster and less expensive to implement, but would have less fuel efficiency, more maintenance time and cost and twice the chances of engine failure.
