Railroad Thread
Re: Railroad Thread
Meanwhile, at the intersection of railroading and "aviation": https://www.thedrive.com/the-war-zone/4 ... a-big-deal
Re: Railroad Thread
Don't put your trains in the attic.
Total Train Disaster: 9/25/2021
https://news.google.com/articles/CAIiEP ... id=US%3Aen
If I’m seeing right, the locomotives are on the track.
Re: Railroad Thread
With NTSB investigating, there'll be zero information disclosed outside of their periodic briefings. In a photograph in the article linked below (scroll down the page to see) the train was moving from left to right - the derailment occurred at or near a siding switch. The fact that the front portion of the train (not shown in this image) is upright and in line, suggests the likely cause will be a mechanical failure on the train (such as a broken wheel) or a track defect that failed as the train was rolling by. The track is required to be visually inspected twice a week; this was last done two days before the derailment.
https://www.npr.org/2021/09/26/10408193 ... estigation
In (post-) Soviet Russia, railroad crossing stops *you*
Re: In (post-) Soviet Russia, railroad crossing stops *you*
I like that it allows you to cross after wrecking your car.
Re: Railroad Thread
Can someone please explain the presence of this ridiculous thread in a premium aviation forum that has absolutely nothing to do with Squid?
Multiple bannings please moderator.
Re: Railroad Thread
Do you have definitive factual evidence that squids are not involved in these railroad-related anomalies?
I didn't think so.
I didn't think so.
Re: Railroad Thread
There are several of these on the internet. i chose the shorter version. You're welcome.
Squid Game vs Train | Stops the Train | Beamng.drive | Train Simulator
https://www.youtube.com/watch?v=RoOc91xqv5E&t=4s
Oh dear
I don't think this is going to buff out: https://twitter.com/virtual_railfan/sta ... 4814906368
Wind shear ahead…Go Around!
Mild ironing: Railroads dealing with wind somewhat as aviation does…
I’m thinking of videos of trains blowing through semi trucks….oh no…a headwind.
I also doubt that crosswinds are a major concern.
Then again 300 10 by 15 flat surfaces perpendicular to the wind is some drag (with “drafting” and wake turbulence acknowledged).
Turning downwind likely does reduce airspeed.
Finally- are we really gonna stop the train because of a headwind?
Maybe the engineer can tune in nearby ASOS frequencies?
https://www.bnsf.com/news-media/railtal ... 2wz5lJYq5w
Re: Railroad Thread
Have people been following this saga? https://www.cbc.ca/news/canada/calgary/ ... -1.6403610
Lot of drama, head of the TSB investigation called for a criminal investigation halfway through and got sacked...
Re: Railroad Thread
Interesting…
As an outsider ass hat parlour talker, I THOUGHT there were requirements to set hand brakes on stopped trains…or maybe not…
A fair bit of Swiss cheese, that the brake system must have frozen enough to prevent repressurizing and then reapplying the brakes.
I think we should redesign brake systems with two air lines…one to keep reservoirs changed and the other to control the brakes.
Cowboy Monkey Improvisation and insidious system interactions...
Fascinating story...seems like several analogies to aeroplanie total disasters...
A problem, a work-around, the fix disables a safety system, problem A leads to B leads to C and leads to did diededness...
https://www.youtube.com/watch?v=wJqFqsoVUCI
I am tempted to post this there to inspire Evanie and irritate the moderators... But those weenies will probably delete it.
Ban all dump trucks!
Chicago-KC train hits truck in the state of Flyover.
No thread at Railherald yet.
https://www.kmov.com/2022/06/27/reports ... -missouri/
Ban ALL gaps
This is our local equivalent to the famous "mind the gap": cuidado con el espacio entre el tren y el andén, "beware the space between the train and the platform". I'm Not_El Experto on warning signs, but I find it excessively long and impractical. We should find something shorter and catchier.
Re: Ban ALL gaps
Any proposal? Guarda con el agujero?This is our local equivalent to the famous "mind the gap": cuidado con el espacio entre el tren y el andén, "beware the space between the train and the platform". I'm Not_El Experto on warning signs, but I find it excessively long and impractical. We should find something shorter and catchier.
Re: Railroad Thread
el idioma español es detallado.
Re: Ban ALL gaps
Make a Warning Sign Department, put me in charge of it, assign me copious amounts of money and, in a couple of years, I may come up with something like ¡No metas la pata!Any proposal? Guarda con el agujero?
(For Los No Hablantes del Idioma Español: meter la pata, literally "to put the foot in", means to screw it up).
CONCUERDO plena, total, absoluta e íntegramente con tu acertada observación sobre este asunto ("CONCUR").el idioma español es detallado.
Re: Ban ALL gaps
Mindo el gapo?This is our local equivalent to the famous "mind the gap": cuidado con el espacio entre el tren y el andén, "beware the space between the train and the platform". I'm Not_El Experto on warning signs, but I find it excessively long and impractical. We should find something shorter and catchier.
If there are any unfamiliar with the joke, Americans are known for trying to "translate" English to Spanish by adding an "o" or an "a" to the end of most words.
Re: Railroad Thread
I guess it is time to post this old British safety sign.
https://www.pinterest.com/pin/339810734387856382/
Help from Agriculture
Peligro!
Pesticidas!
-De nada
Pesticidas!
-De nada
Re: Railroad Thread
There, I updated it.I guess it is time to post this old British safety sign.
Re: Railroad Thread
US Railroad employees are threatening a strike.
The scheduling/dispatching situation seems insane, that workers have extremely limited ability to schedule off time…on the call for work, including many of those shifting sleep situations…It seems that airlines and hospitals can figure it out.
There has been a recent increase in “3-mile” trains, which saves on labor, but screws up passing sidings and makes breakdowns more cumbersome.
Perhaps train crews are paid too much….making management almost vengeful in their scheduling and work rules. I’ve seen engines with engineer, conductor and brakeman- where normal duties are speed up, slow down and liberal stop and wait. The brakeman does have work for set outs and brake hose failures.
Target date: 9/16/2022
Re: Railroad Thread
Delivery vehicle struck by train.
The video attached to this link is not for the squeamish. Please think twice before viewing. A woman's heartbreaking comments can be heard on the video.
https://boingboing.net/2022/10/27/cute- ... video.html
