737 Max troubles;:The latest news...
F.A.O.: Verbie
Postby Not_Karl » Tue Jan 09, 2024 5:31 am
We should cut Boeing some slack. It is understandable for an inexperienced manufacturer to commit a couple of small errors on a new, revolutionary, clean-sheet design.
Verbal
Re: 737 Max troubles;:The latest news...
Postby Verbal » Tue Jan 09, 2024 5:45 pm
No.
On a philosophical note...
Postby 3WE » Tue Jan 09, 2024 6:22 pm
I saw this as a meme on Facebook today with a reference to VerbBrad, Inc.
When one door closes, another one opens.
Re: F.A.O.: Verbie
Postby 3WE » Tue Jan 09, 2024 8:18 pm
Indeed on giving Verbie some slack: Mrs. 3BS car is being recalled as the front bumper assembly may fall off.
Ban ALL engineers!
Re: F.A.O.: Verbie
Postby elaw » Tue Jan 09, 2024 9:28 pm
Okay I'm confused.
I was taught that if something moves and it shouldn't, use duct tape. And if something's supposed to move and won't, use WD-40. Where does this fit in?
Re: F.A.O.: Verbie
Postby Not_Karl » Tue Jan 09, 2024 10:57 pm
I was taught that if something moves and it shouldn't, use duct tape....
Mee too, but thanks to them interwebz I have discovered other options. Example: if a passenger moves you use zip-ties.
From AvieHeraldie....
Postby Not_Karl » Wed Jan 10, 2024 1:22 am
On Jan 9th 2024 Alaska Airlines reported a number of their B39M aircraft showed loose parts during the inspections following the door plug separation, too.
Maybe Boeing should increase the frequency and intensity of Verbie and PPie's physical punishments; they appear to be very distracted...
Postby Gabriel » Wed Jan 10, 2024 5:43 am
Oh boy. Ban the -900ER too...
Postby 3WE » Thu Jan 11, 2024 12:54 am
A conservative talk-radio dude was flaming Alaska today, saying 1) The aircraft had had numerous pressure warnings and 2) Alaska had decided to not_operate that aircraft over water.
I find #2 a bit disturbing- “yeah, if we suck some people out, there’s better odds of finding them by on the land..,”
Postby Gabriel » Thu Jan 11, 2024 4:35 am
I don't know if you guys realized. This is a 737-900ER (sorry 3WE, the specificity is needed in this case).
And it features the exact same plug option than the Alaska 737-MAX-9 of the blown plug accident.
Assembled in the same Spirit facility.
And Alaska, United and Delta operate about 10 times more of the 737-900ER with the plug than of the 737-MAX-9 of the plug.
And the FAA grounded and mandated inspections on the MAX-9.
But it did neither for the 900ER.
Postby elaw » Thu Jan 11, 2024 12:47 pm
At this point if it's Boeing... I think I'll take the train.
Postby 3WE » Thu Jan 11, 2024 12:51 pm
I have no objection to type specificity.
The 172M has 40 degrees of flaps and a different starting procedure than the 172P…along with its 30 degrees of flaps.
But to Evan, that nullifies stuff like FTPAP, P+P=P, and if you let ANY autopilot fly the plane watch it, especially during landings, go arounds, or if you are not sure how to fly at 6000 feet in VFR.
Brief thread hijack
Postby 3WE » Thu Jan 11, 2024 12:54 pm
On a related note, Amtrak canceled the Trans Flyover Express on Monday and Tuesday due to a mundane snowstorm. I guess the localizer wasn’t working on their new Siemens locomotives…or doors were blowing out [shoulder shrug emoji]?
Postby elaw » Thu Jan 11, 2024 2:06 pm
LOL
https://www.ismyplanea737max.com/
(Apparently no longer working but the thought is what counts...)
Postby Not_Karl » Thu Jan 11, 2024 10:45 pm
I shall remind you again of this.
Postby elaw » Tue Jan 16, 2024 2:43 pm
https://www.reddit.com/r/aviation/comme ... _every_18/
Technically should be in the "Reddit" thread but just couldn't resist posting it here. :mrgreen:
Postby elaw » Wed Jan 17, 2024 8:00 pm
More very detailed tech info on the max and its not_door: https://www.youtube.com/watch?v=5FcyvFfHsjQ
Postby ocelot » Mon Jan 22, 2024 6:22 am
Pressurization control fails, gets MEL'd, now you're not ETOPS-eligible. Might be connected somehow but it's hard to see how.
Postby Gabriel » Mon Jan 22, 2024 4:47 pm
Finally! Short of "mandating" it, the FAA issued an SAFO (Safety Alert For Operators) recommending that "operators perform key portions of the Boeing 737-900ER Fuselage Plug Assembly Maintenance Planning Document (MPD) Inspection Tasks, related to the 4 locations where a bolt/nut/pin installation is used to secure the door to the airframe, as soon as possible".
And they link this recommendation with AD for the 737-MAX9 to inspect the mid-cabin door plugs in the wake of the Alaska accident since, according to the SAFO, "the Boeing 737-900ER mid-exit door plugs have an identical door plug design to the 737-9 MAX", and also "some operators have conducted inspections on the 737-900ER mid-exit door plugs and have noted findings with bolts".
https://www.faa.gov/sites/faa.gov/files ... 7900ER.pdf
Postby elaw » Mon Jan 22, 2024 5:39 pm
"...findings with bolts."
Wow, could they be any less specific? "We inspected our aeroplanies and found some issues with some things". :roll:
Postby elaw » Tue Jan 23, 2024 12:08 am
Why yes... https://www.youtube.com/watch?v=yKX0ydWYDzc[url]
Those people know that "having a screw loose" is a figure of speech, and you're not actually supposed to do that on airplanes... right?
Postby elaw » Tue Jan 23, 2024 1:57 am
Postby Not_Karl » Tue Jan 23, 2024 4:16 am
Ban ALL nuts, bolts, screws and pins.
Rivet EVERYTHING.
Postby Gabriel » Tue Jan 23, 2024 5:47 am
Postby 3WE » Tue Jan 23, 2024 12:02 pm
Yes.
While you guys don’t know everything, you have different priorities than MBAs and Marketers.
