A2A Simulations V-tail Bonanza
This plane isn't new, but it's new to me. I won a copy of this Bonanza for FSX a couple weeks ago and finally had time to try it out today. I'm very impressed with it and still have much to learn. According to those who know, it's pretty realistic. Biggest thing I need to learn right now is how to properly lean the engine.
Re: A2A Simulations V-tail Bonanza
Look for some sort of red, starry lever...pull on it.Biggest thing I need to learn right now is how to properly lean the engine.
If you are "high" you will first note a power increase...then the engine will start to misfire. Move the lever back to where the power is good.
A fancy virtual aeropanie like a Bonanza probably also has an EGT gauge. Try to maximize that. That may go against the FCOM, but this is MSFS, peak EGT maximizes your virtual power, and who gives a $hit if you cook your virtual exhaust valves?
You're welcome.
Dude you're handing out some bad advice!
Back in the day, virtual exhaust valves used to be super-cheap, or even free if you knew where to look for them. But now due to global materials shortages, they've gotten very expensive. So it's worthwhile to make sure you use proper leaning procedure to avoid having to replace them prematurely.
Oh the ironing (literally)Dude you're handing out some bad advice!
As a child of the 70's it was all about saving av-gas...maximizing 'MPG' if you will.
But don't forget, we have to balance plug fouling- AND THE ENVIRONMENT-KILLING PRODUCTION INCOMPLETELY BURNED HYDROCARBONS!
AND SORRY TO SPOIL THE FUN- WHY MESS WITH VIRTUAL MIXTURES...Flight sim's exist to land in gusty crosswinds, and to complete approaches when you are 2X too high in an Airbus, AND TO TURN FINAL WITH 600,000 VIRTUAL LBS IN TOW AND PISSY LITTLE PLASTIC POWER LEVERS BETWEEN YOUR THUMB AND FOREFINGER
I hope you are Not_a virtual doctor...Bonanza for FSX...
No, but in my younger days I was an ambulance EMT. Hoping that doesn't wind up causing my virtual death falling from the virtual sky.I hope you are Not_a virtual doctor...Bonanza for FSX...
It's all very clear to me now.Look for some sort of red, starry lever...pull on it.Biggest thing I need to learn right now is how to properly lean the engine.
You're welcome.
