NTSB reports that the cause of a United Airlines' plane almost crashing into the ocean was the failure of the pilot(s) to prevent the aircraft from almost crashing into the ocean: https://www.cnn.com/travel/united-fligh ... index.html
That's some fine police work there, Lou...
Link to the actual report (PDF): https://data.ntsb.gov/carol-repgen/api/ ... 106734/pdf
NEWS FLASH
NEWS FLASH
Re: NEWS FLASH
Ugh.
I dunno…keep you hands on the power levers and the nose up in a measured FDnH manner.
Re: NEWS FLASH
Another case of the pilot flying not using the primary flight display to primarily fly the plane.Ugh.
Ban the ocean
One would think that the existence of the ocean and the pilots knowingly flying over it would be considered at least contibuting factorsNTSB reports that the cause of a United Airlines' plane almost crashing into the ocean was the failure of the pilot(s) to prevent the aircraft from almost crashing into the ocean...
Re: NEWS FLASH
Maybe with a little extra emphasis in the first few minutes after takeoff when flying in turbulence…Another case of the pilot flying not using the primary flight display to primarily fly the plane.Ugh.
Then again, those whacky humans doing an extremely routine operation for the umpteenth time and momentary lapse of attention…
Re: NEWS FLASH
So the PF not using the PFD to FDP (fly da plane)?Another case of the pilot flying not using the primary flight display to primarily fly the plane.Ugh.
Re: NEWS FLASH
Neither was the PM using CRM to monitor the PFD, AI, ALT, VSI and GlutealAAccelerometer and help the PF FDGDA...especially during the DP...WTPhugoid?.So the PF not using the PFD to FDP (fly da plane)?
