https://www.facebook.com/reel/104254942 ... tid=roAVj8
I see some footwork.
I hope she had someone to help her with the flat-screen.
No ITS devices.
No ITS devices.
Re: No ITS devices.
You guys know I am always the negative guy.
Very nice footjob,. I mean rudder work.
But why did the stall warning briefly sound upon rotation?
Rotated at a too slow airspeed?
Rotated too briskly?
She was not practicing a soft field or short field take off (where you lift off at minimum speed), since she didn't level off in ground effect to build speed.
Maybe a bit of windshear?
Re: No ITS devices.
And Not_a single vertical stabilizer snap. What a difference good-American-metal instead of cheap-Eurotrash-composites make.I see some footwork.
Re: No ITS devices.
Eric’s Reversals:
Brill yunt comment! Hopefully she receives electro shock therapy and deep hypnosis during her airline training to pause at neutral, mechanically utter memory checklist items and remove her feet from the pedals when 100 feet above the runway.
Gabieeee:
In my not_vast 172 experience a stall chirp is not_uncommon during any sort of “high performance” takeoff. It requires a shred of common sense that the takeoff has proceeded normally, the airspeed is correct, the attitude is as it’s supposed to be. The memory checklist for said stall chirps?: DO NOT_PULL UP RELENTLESSLY. Sure it could be a random shear-speed loss or a sudden gravitational anomaly and yes, check your airspeed…I guess you can think extra about stall prevention, but if the chirp stops, return to your normal , first-rate attention to traditional, fundamental airgirlship during the mildly critical takeoff phase.
Gabieeee:
Re: No ITS devices.
Now just remember kids: the best way to prevent a stall is to never leave the ground!
Re: No ITS devices.
Fixed.Now just remember kids: the best contraceptive is ponerla nitrate!
Re: No ITS devices.
I'm relieved to Not_see "Not_Karlie will explain" at the end of your postFixed.Now just remember kids: the best contraceptive is ponerla nitrate!
Re: No ITS devices.
3BS does not_comprende and wishes that one of the Malos Aeres natives would explain.I'm relieved to Not_see "Not_Karlie will explain" at the end of your post
Ironingly, I think it’s nitrate that I don’t understand, even though it’s a great agricultural fertilizer.
As to “ponerla”, because of my experience with Puerto Ricans who wish to relax and take it easy, I may be at least partly on the way.
Is “nitrate” a colloquialism for tres-nitro tolueneo (cue an acronym)?
Re: No ITS devices.
…and the second best way to prevent a stall?Now just remember kids: the best way to prevent a stall is to never leave the ground!
No, Gabriel, it’s not_monitoring the AOA indicator.
You're on the right track (or runway) about "ponerla".
That's easy, relentlessly pulling up. Or maybe banning ALL stalls?…and the second best way to prevent a stall?
"El mejor anticonceptivo es el nitrato de ponerla".3BS does not_comprende and wishes that one of the Malos Aeres natives would explain.
"Ponerla" = "to put it". It is, of course, a vulgar expression when referring to THAT "it", as in this case.
"Nitrato" = "nitrate".... BUT, if we take "ni trato" as two separate words, then it means "I don't even try to".
So, literal translation: "the best contraceptive is to put it nitrate". Translation of the meaning: "the best contraceptive is I don't even try to put it".
De nada .
(Please note that I, as a 50-year-old-virgin like we all are, am Not_too versed on this "ponerla" subject, but have heard that it may involve nairy parts).
Re: You're on the right track (or runway) about "ponerla".
Da, gracias.De nada .
I am disappointed that tres-nitro tolueno, and it’s acronym, did not come into play.
