What's that noise?!
Site Admin
What's that noise?!
Postby monchavo » Fri Nov 28, 2008 10:47 pm
I flew from Budapest to Gatwick recently on a BA bird, don't recall the type, sorry folks.
2 engined airbus of some sort.
When we landed there was an extended and rather interesting sound that I can only
say sounded very much like sawing. It happened as we were preparing to disembark the aircraft
and lasted 30-40 seconds. Clearly, nobody had taken a many-toothed instrument
to the aeroplane, but I am interested in what causes this phenomenon.
Smart arse comments stick to off-topic please.
aardvark2zz
Re: What's that noise?!
Postby aardvark2zz » Sat Nov 29, 2008 12:46 am
Passenger tunnel moving towards plane.
Postby flyboy2548m » Sat Nov 29, 2008 12:09 pm
You were on a 319/320 and what you heard was the famous/infamous Airbus PTU. I bet you also heard it during startup for a few seconds.
Dmmoore
Postby Dmmoore » Sat Nov 29, 2008 3:40 pm
To expand on flyboy's post slightly. A PTU (Power Transfer Unit) is a device that uses hydraulic motor in a system with pressure drive a pump in a system without a source of pressure.
Many aircraft use a similar device but none are as noticeable as the A320 series.
Site Admin
Postby monchavo » Sat Nov 29, 2008 4:49 pm
"The PTU is mechanical pump that links the yellow and the green hydraulic systems. It is energized when either system has been turned off( ex: one engine off) it produces a loud high frequency noise when it turns and produces 3000 psi hydraulic pressure for oppsosite system."
OK. Thank you for the information. What is the practical application of such a system? What would I need that hydraulic pressure for?
Site Admin
Postby monchavo » Sat Nov 29, 2008 4:55 pm
Amusing Salon.com article about this phenomena
http://www.salon.com/tech/col/smith/200 ... epilot170/
Giles
Postby Giles » Sat Nov 29, 2008 5:23 pm
from the article you referenced;
"The A320 has two main hydraulic systems that operate flaps, landing gear, flight controls, cargo doors and brakes."
Postby flyboy2548m » Sun Nov 30, 2008 4:25 am
Yeah, you know, little stuff like that. To add, the A320 has three hydraulic systems, not two.
